single slot card required
The only one i can think of thats a single slot which is around the same is the 7950 GT, everything else is dual slot, your limited looking for single slot.
Sapphire ATI Radeon X1950 Pro 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
580MHz Core, 1400MHz Memory, 36 Pixel Shaders, 8 Vertex Shaders, 8 Geometry Pipelines, Shader Model 3.0, Crossfire2 Compatible.
Sapphire 10+ in stock £114.99
(£135.11) ... is easily faster than your current card.
Another good choice is ...
Leadtek GeForce 7950 GT 256MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
550MHz Core, 256MB 1400MHz GDDR3 Memory, 24 Pixel Pipelines, SLi Ready, 2yr Warranty.
Leadtek 10+ in stock £144.99
(£170.36)
Is it? I don't think so... I'd say the X1800XT was a bit faster.
X1800 XT 512MB is faster in almost all circumstances, there are one or two the raw shader power of the X1950 Pro props it up though and in any case the performance is very close.
