single slot
12 Nov 2002
Herts
What's the fastest single slot gfx card currently available ?
Has to be air cooled and not much wider than 1 PCI-E slot
MW
Well you're out of luck, 9800GT/4850 are pretty similar in terms of speed and there's nothing faster with a single slot cooler iirc.
Have you got space above the card? One of these http://www.overclockers.co.uk/showproduct.php?prodid=HS-053-TR&groupid=701&catid=57&subcat=787 will only take up a single slot when fitted so it wraps around it.
Edit:
It will however work on a 4870 which is a worthwhile upgrade from your card (just) whereas a 250GTS is barely any faster.
