Sir Fred - ( Remake ) Retro Winner [ Platformer ]
Caporegime
8 Sep 2006
On Ocuk
...Once upon a time there was a wise old king who ruled over a happy land.
Everyone lived happily ever after - except wicked Baron Hugh D'Unwyt and the king's daughter, whom he's kidnapped.
As all the other knights are away a-questing, it falls to the aged and corpulent Sir Fred to rescue her...
In classic arcade-adventure style, SIR FRED has to collect object and solve problems as he penetrates the defences of Castle Feare, the Baron's stronghold.
The objects are found in different locations each time you play, which complicates mapping somewhat, but must be used to complete the various tasks which you'll need to do.
They can be picked up using the Select key and are displayed along the bottom of the screen.
A yellow box highlights the currently selected object; to use this object, press the Use key.
The objects that you can collect are:
rope, cross, score, stool, bait, tap, bottle, bow & arrow, chicken, stones, flute, keys, torch, matches, sword
Some weapons can only be used a limited number of times, so a little counter appears above the window and decrements every time the object is used.
Once the counter gets to zero, Sir Fred loses the weapon and will need to find a replacement! There are a number of weapons to be found including a sword and a bow and arrow.
SIR FRED himself has only a limited amount of energy (and only one life) so you'll need to use the weapons to defend him from the various creatures inhabiting the castle.
http://cezgs.computeremuzone.com/eng/card.php?id=8#
