Siri equivalent for Moto Razr i
25 Jan 2013
I've just got a Moto Razr i as a play thing and I want an app that'll work as a Siri equivalent. The main thing it needs to do is be activated from my pin locked home screen with a key press so that I can skip tracks, make calls and send texts when driving.
Can anyone point me to what I need? I installed something called Assistant but this can't be activated from the lock screen.
Thanks
#29
I know you can do it with a bluetooth headset but I don't think it's possible from the pin locked screen as it would kinda defeat the object of the pin?
Closest I can think is use Smart Actions to set up a rule that the phone doesn't sleep while charging or in the ca via bluetooth proximity and loads Google Search so then you could just say 'Google' and tell it what to do.
The phone isn't connected to the car via Bluetooth, it's a lead from the 3.5mm jack to the auxiliary connector.
