I've been trying to setup a site to site VPN for a while and I've sort of got it working however it's far from perfect. Hoping for a few suggestions to get everything working properly.
Current setup
Site A - IP range is 192.168.0.x
VM Broadband (SuperHub)
ESXi box with Server 2012R2 (DC/DNS/DHCP)
Site B - IP range is 192.168.10.x
Sky Fiber (using the new black Sky router)
I installed Logmein Hamachi a while back (mesh network) on both 2012 servers and set a static route between them. This works fine between both machines and I can ping by hostname/IP without any issues. They also seem to replicate AD data without any problems. Both DC's can see client machines on their own side however can't see any machines on the other side unless Hamachi is installed on the client machine. I can ping or RDP to the client machines on each side by the Hamachi assigned IP however if I try by Hostname it either tries to resolve to the local IP for the machine (if there is a DNS entry) before timing out or doesn't resolve the host at all.
Is there an easy and free or fairly cheap way of sorting this (I feel like I'm missing something obvious)? Ideally I'd like to ditch Hamachi as it's no longer free and seems to be over-complicating things. I did try and set up a pfSense vm at either end a while ago however had issues on the Sky side (couldn't get a WAN IP to show). Was hoping when I got fiber installed a few weeks ago I'd be able to ditch the Sky router and use the Openreach one but Sky seem to be doing all-in-one router/modems again so I'm stuffed there
. I've started mucking about with SCCM, Lync and Exchange and these are all set up at site B so I'm going to need them to be able to talk to site A without any issues as well.
Current setup
