Hi Guys
First time poster but long time reader of forums. I'm wanting to connect my current home network to the network I've setup at my parents but am having a lot of bother in setting this up. I don't really know anything about VPN's etc and am unsure on the best way of doing this. There is a Server2008r2 machine at each location at present dealing with AD/DNS/DHCP. Current setup below:
Site A
Server1 (Esxi5): Running 2008 R2 (AD, DNS, DHCP).
NAS01: Running UnRAID (used primarily as media server and local storage of user files/backups).
Router: VM Superhub.
Broadband provider: Virgin Media (50Mb).
IP range: 192.168.0.xxx
Gateway: 192.168.0.1
Domain: home.local (local domain).
Site B
Server2 (Esxi5): Running 2008 R2 (AD, DNS, DHCP).
NAS02 (Esxi5): Running UnRAID (used for same purpose as NAS01)
Router: Sagemcom F@ST2504n (Running base Sky firmware)
Broadband Provider: Sky (approx 6Mb)
IP range: 192.168.1.xxx
Gateway: 192.168.1.1
Both servers were originally set up on the same site and Server2 was set to replicate server1 for AD. Both servers were talking quite happily to each other on the same network before I moved server2 to its current location. Both servers have two NIC's installed (Promiscuous mode enabled on the NICS for the VM's)
I assume I need to setup some form of VPN tunneling however am unsure on the best way of doing this. I've seen a few posts about Logmein Hamachi however I believe the best way of setting this up would be as a mesh network. I tried following a guide for this (Link) which advised enabling IP routing on both machines and setting static routing between the two servers however I get errors when trying to do step 10 (setting the static routing). I can browse both servers shared folders using the Hamachi program but can't browse them using computer/explorer.
Is there an easy way to set this up or another tool/way of doing this? I don't mind using any of the built in stuff in 2008 but I assume the default VPN roles/features options wouldn't be any use to me as I don't have static WAN IP's for the internet side of things. I've also noticed the Sky firmware on the router is really poor with no static routing options (best it has is the usual DMZ option for a single IP and an option to setup a dyndns account). Can't remember what the VM hub has but I'm sure it's got a lot more options including static routing.
Can anyone offer any advice on the best (easiest) way of setting this up?
Site A
Site B
Thanks for the help so far guys.
