site works with firefox but not IE - help please
15 Feb 2003
Europe
I know next ot nothing about webdesign but took it upon myself to create a site for the new lacrosse team i've started. This is the first site i've made.
The site is located at http://www.eastcoastbaby.co.uk The problem is that the league tables on the right, while they work fine on firefox, appear below the central colulmn when viewed with IE, rather than on the right hand side.
Can anyone tell what i've done wrong here?
I use linux and so find it very difficult to test with IE.
the style sheet is at www.eastcoastbaby.co.uk/base.css
Thank you.
Just so you know, the site appears to be working perfectly in IE7 Beta3, all the league tables are on the right hand side of the page :)
It's fine if you view it maximised I've noticed, if you set the middle column to a minimum width then it'll be fine because the league results go under the middle column when it gets to a certain width.
thanks guys, I veiwed it on my flatmates lappy with IE at 1024x768, what should i set the minimum middle column width at and whats the code for that?
