Sitecom Routers and Media Streamers now available at OcUK, Sitecom products are developed to offer a user-friendly “out of the box” experience and feature the latest wireless technology to reduce dead spots, improve range and increase speed..
Full Range
Sitecom WL-306 Wireless N 300Mbps Gigabit Cable Router @ £72.99 inc VAT
Use this Sitecom Wireless Gigabit Router 300N-XR to set up a wireless home/office network with superior throughput and an unparalleled wireless range. This Router enables you to wirelessly share files and broadband Internet access, as well as the peripheral devices attached to the PCs in your network. Thanks to the integrated WPS technology, this Router makes it easier than ever to connect and protect your PCs or laptops in a wireless network. Just one press of the button, and the wireless connection is established, including automatic transfer of the WPA security included in the Router.
Suitable for Cable and ADSL Modems.
- Giga performance with this Sitecom 1000 Mbps wired speed, ideal for HD Streaming. 300 Mbps - wireless speed
- Extended range due to XR Technology - less dead spots
- Easy set up and security - create a safe wireless connection in just one click
- Suitable for Cable and ADSL Modems
- 10 Year Sitecom Warranty
- Includes McAfee Internet Security Suite
- System Requirements:
- Ethernet ASDLor Cable Modem
- PC's and Notebooks with 300N client adapters (recommended)
Only £72.99 inc VAT.
ORDER NOW
Sitecom WL-308-UK 300Mbps Wireless Gaming Cable Router @ £105.99 inc VAT
The Sitecom 300N XR Gigabit Gaming Router is ideal for the fanatical gamer who expects lag-free gaming experiences, and hardcore users who want to optimize their network and internet experience. This router automatically recognizes application patterns inside the data stream and assigns priority to those applications that require the best response times for optimal bandwidth usage. This intelligent technology called stream engine, guarantees optimal wireless or wired performance and efficiency for applications such as voice over IP, gaming, video streaming or downloads. The 'Quality of Service' functionality is activated automatically, it's not necessary to install any program or configure anything to make use of this advantage. This 300N draft 2.0 Gaming Router with Intergrated Gigabit Switch includes WPS (Wi-Fi Protected Setup). Users can network wirelessly at speeds of up to 300Mbps in a secure enviroment without the hassle of a manual set up device.
- StreamEngine Technology ensures low latency online, lag-free local network gaming experience and uniterupted VoIP calls
- Automatic 'Quality of Service' enhanced classifies time sensitive applications and gives priority within the network traffic
- Pre configured application level gateways for the most recent popular multiplayer games, and customizable settings for new games
- WISH - Wireless Intelligent Stream Handling for the internal wireless network
- Advanced scheduled access control
- Up to 30,000 simultaneous open connections
- XR extended range technology reduces dead spots and guarantees high performance
- Share high speed wireless internet up to 300Mbps routing speed, Ideal for gaming, streaming videos, file sharing and voip.
Only £105.99 inc VAT.
ORDER NOW
Sitecom WL-330 300Mbps Wireless Range Extender @ £59.98 inc VAT
Extend the wireless range of your network by using the Wireless Network Range Extender. The wireless range extender guarantees an optimal extended cover and reduces “dead spots” so that you can enjoy a stable network connection on the ground floor and in the loft or other rooms in the house including the garden, or home-office. The Wireless Network Range Extender can also be used to give any device with an Ethernet connection, such as gaming consoles or homeplug adapters, wireless capabilities. The device is easy to install and is compatible with 802.11 b/g/n wireless networks.
- Compatible with IEEE 802.11b/g/Draft-N wireless network standard - works with other 802.11b/g/Draft-N wireless devices
- High speed wireless network, six times faster than conventional 802.11g wireless network (up to 300Mbps)
- Supports DHCP server function.
- Supports 64/128-bit WEP, WPA, and WPA2 wireless data encryption.
- Supports MAC address filtering (Only allow specific wireless device of your choice to connect to this access point).
- Supports RADIUS server, only allow users listed in your authorization server to use wireless network
- Easy to use web-based GUI (Graphical User Interface) for network configuration and management purposes.
Only £59.98 inc VAT.
ORDER NOW
Sitecom WL-348 300Mbps X3 Wireless N ADSL 2+ Modem/Router @ £72.99 inc VAT
Use this Wireless ADSL 2+ Modem Router 300N X3 to set up a wireless home network with superior throughput and an unparalleled wireless range. This Router enables you to wirelessly share files and broadband Internet access, as well as the peripheral devices attached to the PC’s in your network.Thanks to the integrated WPS technology, this Router makes it easier than ever to connect and protect your desktop PC’s or notebooks in a wireless network! Just one press of the button, and the wireless connection is established, with automatic transfer of the WPA security included in the Router. Thanks to the built-in ADSL modem, you can connect this Router directly to your ADSL line.
- Superb Performance - 300 Mbps Wireless network speed
- Full "out of the box" secured
- Built-in ADSL 2+ modem
- Create a direct connection to your ADSL line
- 10 year manufacturers warranty
ORDER NOW
Sitecom MD-270 Full HD 1080p TV Media Player With Remote @ £99.99 inc VAT
With the Sitecom TV Media Player, you can play digital movies and music or view photos directly on your TV. The device supports most common media files with full HD (1080p) quality for an optimal visual experience. The TV Media Player automatically connects to other UPnP AV devices (Universal Plug and Play Audio and Video) in the network, such as a PC or Home Storage Center. The intuitive menu can be used to easily access and play files that are stored on the network. The device has two USB ports to which an external hard drive or a USB stick can be connected. Thanks to the remote control, you can play the files from the comfort of your chair.
- Play digital movies, music or photos directly on your tv!
- supports most common media files with full HD (1080p) quality.
- Two USB ports to which an external hard drive or a USB stick can be connected.
- Thanks to the remote control, you can play the files from the comfort of your chair.
10 years manufacturers warranty.
- Connections:
- 1x HDMI 1.3a
- 2x USB 2.0
- 1x S/PDIF for digital audio
- 1x Composite for video and stereo audio
- Image resolutions:
- Normal (4:3)
- Widescreen (16:9)
- 480i, 480p, 576i, 576p, 720p, 1080i, 1080p
- Audio:
- Up to 24 PCM
- MPEG
- Dolby Digital
- DTS pass-trough
Only £99.99 inc VAT.
ORDER NOW
Sitecom WL-355 Wireless Full HD 1080p TV Media Player With Remote @ £132.99 inc VAT
The Wireless Network TV Media Player enables you to wirelessly play your digital movies, music and photos directly on your TV; guaranteeing optimal comfort and the best possible High Definition quality (1080p). Insert the included Wireless Dual-band Media Adapter in the USB port and wirelessly stream movies with maximum speeds up to 300 Mbps.
- 1x HDMI 1.3a
- 2x USB 2.0
- 1x Composite for video & stereo
- 10/100 Ethernet
- Normal (4:3)
- Widescreen (16:9)
Only £132.99 inc VAT.
ORDER NOW
Full Range
ORDER NOW
ORDER NOW
ORDER NOW
ORDER NOW
- Connections:
- 1x HDMI 1.3a
- 2x USB 2.0
- Normal (4:3)
- Widescreen (16:9)
- Audio:
- Up to 24 PCM
- MPEG
- Dolby Digital
- DTS pass-trough
ORDER NOW
- 1x HDMI 1.3a
- 2x USB 2.0
- 10/100 Ethernet
- Normal (4:3)
- Widescreen (16:9)
ORDER NOW
