Sites to help find what to play?
4 Jul 2009
Kilham, East Yorks
So I completed HZD yesterday and loved the game, however now I'm struggling with what to play to fill gap until Cyberpunk comes out, is there any sorta suggestion sites or subreddits out there?
Not the same but the xbox app has a surprise me button which picks a game for you to play next.
That'd actually be a pretty cool steam feature, especially if you can narrow down the suggestions to either games similar to what you play or certain genres
Where? I've only ever seen it on store and even then its a bit hit and miss IMO
That's probably what I mean,when I scroll down in the store it comes up with ' you played this,so we thought you might like this'
But yes definitely hit and miss but I imagine every recommendation will be.
The latest library format on Steam does indeed suggest "games from your library which you've never played, but will probably enjoy based on your recent games".
I think they might have put it more succinctly though.
I use https://www.cdkeys.com/pc
Have a browse and pick up a bargain.
Sorry guys I was meaning more from my own library, I did find a site earlier tho thats helped a bit
Steam Labs has a way to narrow down your search, found a few games that way that I wouldn't normally look at.
Thanks mate, I'll have a look
