(Mods I apologise if this sort of thing is not allowed here, please delete if so)
As some of you may have read in another thread, I'm currently planning a conversion of the PS3s sixaxis electronics/controls into a 360 controller casing.
While waiting on some parts I'm playing around with other ideas, looking for ways to make things fit easier etc etc when I noticed that the sixaxis' battery is infact a very common type and has a mediocre mAh rating. Its a 3.7v 610mAh Lithium Ion battery, almost identical size to those found in the majority of nokia mobile phones; they too are mostly 3.7v, yet the typical model is 900mAh.
For anyone with the most basic soldering skills, the battery is easily swapped for these longer-life models. The nokia battery I had to hand was a BL-5C, found in a nokia 6230, available from the usual aution site for £3, or your local mobile phone shop...
I've tested (including charging via USB), works just fine. £3 for 150% battery life is a bargain!
Self-explanatory pics below....
EDIT: Sorry had to remove pics as my bandwidth limit was hit pretty damn quickly
As I mentioned in another thread I honestly don't think it'll be too long before replacement rear parts of the controller casing are available with the option to have replaceable battery packs.
