*****SIXTH ROUND OF DEALS - LCD / LED MONITORS*****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
Right its monitors time, and well ooooops someone let me loose on the pictures. :D
OcUK Cream 18.5" Widescreen LCD Monitor - Glossy Black @ £79.89 inc VAT
This OcUK Value 18.5" monitor has an industry leading ultra-fast 2ms response time making it perfect for blur-free video and gaming. With it's 2000:1 contrast ratio and digital connectivity there is no other LCD that can match the combination of value and performance.
- Screen Size: 18.5" Widescreen
- Resolution: 1360x768
- Contrast Ratio: 2000:1
- Brightness: 250cd/m²
- Response Time: 2ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Dimensions: 444.0mm x 324.0mm x 170.5mm
- Weight: 3.2kg
- Warranty: 3 Years On-Site
Only £79.89 inc VAT.
ORDER NOW
Samsung B2030N 20" Widescreen LCD Monitor - Glossy Black @ £99.99 inc VAT
Samsung 30 Series monitors are designed to be eco-friendly as well as user-friendly. With efficient power saving and innovative features, they allow you to enjoy using your monitor with the confidence of a clear conscience. The phenomenal 50000:1 Dynamic Contrast Ratio welcomes you to a world of intense, natural colour and incredible, lifelike detail. Combine that with a high brightness of 300cd/m² and you have a monitor that is made for multimedia.
- Screen Size: 20" Widescreen
- Resolution: 1600x900
- Contrast Ratio: 50000:1
- Response Time: 5ms
- VESA Compliant
- Dimensions: 492.0mm x 396.0mm x 178.0mm
- Weight: 4.1kg
Only £99.99 inc VAT.
ORDER NOW
OcUK L-2266WD 22" Widescreen LCD Monitor @ £99.86 inc VAT
The Digimate L-2262WD has an ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 700:1 contrast ratio and digital input there is no other monitor that can match the quality, value or performance.
- Screen Size: 22" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 1000:1
- Brightness: 300cd/m²
- Response Time: 6ms
- Viewing Angles (H/V): 170°/170°
- Dimensions: 510.0mm x 448.0mm x 190.0mm
- Weight: 5.0kg
Only £99.86 inc VAT.
ORDER NOW
Iiyama ProLite E2210HDS 22" Widescreen LCD Monitor - Black @ £129.24 inc VAT
The new ProLite E2210HDS is the latest introduction to Iiyama’s range of Eco-monitors showing a commitment to the environment whilst still offering the latest technology and value for money. The true high definition panel is 1920x1080, 16:9 format and offers fast 2ms response time and 20,000:1 ACR for improved colour in gaming and video applications. It also features the latest triple input configuration of HDMI, DVI and analogue and is Energy Star qualified.
- Contrast Ratio: 20000:1
- Inputs: 1x Analogue & 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 505.5mm x 366.0mm x 180.0mm
- Weight: 3.5kg
Only £129.24 inc VAT.
ORDER NOW
Samsung P2370 23" Widescreen LCD Monitor - Glossy Black @ £133.94 inc VAT
Ultra-slim and ultra-elegant, the Touch of Colour design is inspired by the artistic integrity of hand blown glass. The translucent charcoal gray gradation of the bezel and cobalt blue hues of the clear crystal neck subtly shift in color depending upon external light conditions, creating an exquisite interplay between the monitor and the environment that it is placed in. The ultra-slim 30mm depth not only creates more style in less space but also ensures exceptional all round efficiency. Up to 50% slimmer than traditional monitors, the modern, organic contours gently accentuate the elegance of your lifestyle and home.
- Screen Size: 23" Widescreen
- Inputs: 1x DVI-D (HDCP Compliant)
- Dimensions: 571.0mm x 423.0mm x 190.0mm
- Weight: 4.1kg
Only £133.94 inc VAT.
ORDER NOW
Asus VG236H 23" Widescreen LCD 3D Monitor + Nvidia 3D Vision Kit @ £387.74 inc VAT
Enter an immersive 3-dimensional Full HD 1080p world of games and movies with the VG236H. Through the use of market-leading 3D technology and active shutter glasses, it instantly takes you into another dimension—transforming your gaming experience to 3D*. There are hundreds of popular PC game titles** currently compatible with the NVIDIA® 3D Vision™ kit
- Tilt and Swivel also Height Adjustable.
- Contrast Ratio: 100000:1
- Viewing Angles: (H/V): 170*/160*
- Inputs : 1 x DVI-D & 1 x HDMI
- Weight: 7kg
- 3 Years Warranty.
- Includes Official Nvidia 3D Vision Kit
Only £387.74 inc VAT.
ORDER NOW
OcUK L-2362WD 23" Widescreen LCD Monitor @ £111.61 inc VAT
The Digimate L-2362WD has an ultra-fast 5ms response time making it perfect for blur-free video and gaming. With it's 1000:1 contrast ratio and digital input there is no other monitor that can match the quality, value or performance.
- Inputs: 1x Analogue & 1x DVI-D (Not HDCP Compliant)
- VESA Compliant
- Dimensions: 538.0mm x 440.0mm x 190.0mm
- Weight: 5.3kg
Only £111.61 inc VAT.
ORDER NOW
BenQ G2420HDBL 24" Widescreen LED Monitor - Black @ £159.79 inc VAT
The BenQ LED monitors come with an ultra-high dynamic contrast ratio of 5000000:1 to add colour depth and definition to darkened and complex visuals, so that everything you see - from the brightest white to the darkest black - is perfectly rendered to deliver the most incredible picture performance. The G2420HDBL provides true-to-life 16:9 images that fit the 1920x1080 resolution perfectly. It offers outstanding image quality and a clear view of multiple documents simultaneously to ensure the highest work productivity. With a speedy 5ms response time, even highly dynamic video is rendered with smooth, fluid motion without ghosting or other artifacts to distract your view.
- LED Backlit
- Screen Size: 24" Widescreen
- Contrast Ratio: 5000000:1
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
- Weight: 4.4kg
Only £159.79 inc VAT.
ORDER NOW
Samsung P2450H 24" Widescreen LCD Monitor - Glossy Black @ £189.99 inc VAT
Film fans and gamers will love the Samsung SyncMaster P2450H TFT display! The Samsung P2450H is a 24 widescreen monitor that willplunge you into all your favourite films and 3D games with breathtakingly realisticresults. The P2450H has a fantastic contrastratio for deep blacks and rich colours. Plus, the P2450H has aresponse time of just 2 ms which is great for online games! Plus, the Samsung SyncMaster 2450H has a wide selectionof connections, including an HDMI port for hooking up a HD games console orcamcorder.
- Contrast Ratio: 70000:1
- Inputs: 1x Analogue, 1x DVI-D & 1x HDMI
- VESA Compliant
- Dimensions: 578.0mm x 430.0mm x 190.0mm
- Weight: 5.4kg
Only £189.99 inc VAT.
ORDER NOW
Iiyama ProLite E2710HDSD 27" Widescreen LCD Monitor - Black @ £234.99 inc VAT
The Prolite E2710HDSD 27” LCD Display features a stunning 2ms Response Time and a High Definition 1920x 1080 Resolution. The 20000:1 Advanced Contrast Ratio and 400cd/m² brightness offer the user clear and vivid images, and the DVI, D-Sub and USB connections ensure compatibility across a range of devices including games consoles and work stations.
- Screen Size: 27" Widescreen
- Brightness: 400cd/m²
- VESA Compliant
- Dimensions: 642.0mm x 438.5mm x 210.0mm
- Weight: 6.9kg
Only £234.99 inc VAT.
ORDER NOW
Nice. I like their choice of demo pics: woman, car, or woman&car. :)
edit: lol, just noticed there's one with a game pic... my brain musta not registered that first time round. :D
Whats with the woman on the samsung? At what point did rib cages become attractive and there seems to have been some serious photoshop failing on the chest area. Square boobs anyone?
She is a stunning girl, yeah OK she is a bit skinny, but very attractive and thats before anyone photoshops anything. :)
