Size advice.
12 Feb 2009
UK
I'm looking at a used planet x rt-57 on the bay but it says it's a 53 size which going from the link below is abit small for me as I'm 5.10".
size guide
Do you guys think I could get away with it with a swap of a stem maybe? It's not something I can try before I buy but I'm no pro and this is my first Road bike.
I really like the look of the bike but don't wanna make a big mistake.
Thanks.
I wouldnt.
It doesnt matter if you're a pro or not - everybody needs a bike which fits properly.
