Hi all, theoretical question.
I was wondering if smaller motherboard were in general "warmer" than bigger ones.
It would make sense in terms of physics : on a bigger board, there is more surface to dissipate heat, and to let air flow.
Obviously, temperature will also depend on the materials, processor, cooling, case, etc. But for a same processor, cooling, case and all, did you notice that smaller boards would tend to be "warmer" ? Or is the size factor negligible compared to the other factors?
For example, i read that the Asus Z77 Maximus V Gene Intel Z77 would be good for overclocking, while it's only 24.4x24.4 cm2. Is it because it's made out of other materials, or because of some special features ? (like Fan Auto Tuning and Extreme Engine Digi+, for example?)
There are so many different motherboard that you need some (personal) criteria to eliminate most of them, and read carefully the characteristics of the ones remaining.
I was thinking that size could be such a criterion, to find interesting boards.
For me, the methodology could be :
- first, choose a chipset (Z77 for example)
- then, choose a size
- then, other personal criteria
So... what about this size-temperature relashionship ?
