SK22G2 & 7600GT
22 Nov 2003
Cardiff
This combo ok paired with a 3800+ dual core?
Not performance wise, more worried about the tiny 200w PSU this shuttle comes with and having never bought a shuttle system before, I have no clue in regards to their PSU's.
Shuttle PSU's are very strong.
A Shuttle 200W can power a good spec X2, a couple gigabytes of RAM, and an X1800/X1900 GPU.
If you're really worried, I think you can get a Shuttle PSU bigger than 200W, but really you have very little to worry about :)
Paramount said:
A 7600gt, yes it'll do that. I think putting a 1800 or 1900 XT or above may really stretch it though, even being a Shuttle PSU.
Maybe, but there seem to be plenty of people knocking about with very high end cards in 200W shuttles. :)
Have you decided on what memory you're going for?
I know Air Marshal had problems with some 2GB PC6400, so went for 2GB Corsair Value Select PC5300 instead.
