Skitch Plus
16 Apr 2007
UK
Hey all,
I've been using Skitch for a while - it's pretty good - but having the ability to just click copy and it copying a direct link to the image would be awesome...
Has anyone upgraded and is using Skitch Plus?
Or is there a free alternative? :p
Thanks,
Marky
EDIT: I have just found you can buy Skitch on the app store for £5.99... Does it have more features than the free version I got off their website?
There was a thread in here some time ago expressing the displeasure that a lot of features were removed from the free Skitch package and moved over to Skitch Plus.
It also contains a link where one could update a Skitch account to a Skitch Plus account for free. It might be worth a search in case that link is still active.
I'm fairly sure they were giving a free upgrade for beta members - but I wasn't a beta member :(
If anyone is interested in what the outcome to my dilemma was :p...
I deleted the free app and bought the app from the app store - It's pretty much Skitch Plus minus a few online features :)
I just take a screenshot or drag an image into skitch - click upload and paste in the links :) The links get auto copied, so it's all super easy :)
Only problem is the option to only have it in the Menu Bar currently isn't working - the developer knows of this issue and has said it should be fixed soon :)
