- 1 Sep 2007
- St. Helens & Blackpool
Hi, iv'e just put together a PC with some bits i had lying round, using an Athlon 64 3500+ and an Asus A8ne-FM micro atx motherboard, problem is the cooler on it is a bit naff and the Plastic motherboard bracket has been lost, are there any coolers for Skt 939 that dont need the plastic bracket on the motherboard (ie: use a backplate instead). nothing too big because its only in a smallish case.
