skt 939 cooler
Permabanned
30 May 2006
newcastle
As title says, im wanting to know if theres a cooler that will go straight onto existing oe clips...ive bought a 5770 and one of the guys mentioned trying to o/c the cpu. As its not that good a chip to overclock x2 4400 i wasnt to fussed bout getting fully fledged take off the mobo n brackets evrywhere, but a half descent one if theres one out there......
Anything that fits an AM2 / AM2+ or AM3 should fit a 939 (so long as you don't have to replace the backing plate/retention bracket).
When chose a cooler try to get an older one because those old CPUs run a lot hotter than modern AMD quads. I use to have used an AKASA Evo 120 they were pretty good, an OCZ Gladiator Max will keep your hot baby under control, there still available for less than £25 including post and packing.
Gigabyte GA-MA790FX-UD5P, 955 BE(C2)@3.818 GHz 1.45V, Geil Value 4GB DDR3-1600,
ATI 5850 1GB, CM90 II Advanced, 1TB Western Digital Caviar Black, 4 HDDs, Jeantech Storm 700w,
Asus Xonar Essence STX, Pinnacle PCTV 3010iX Dual Analogue + DVB-T.
