Skt 939 heatsink on skt AM2 Cpu?
2 Feb 2006
Chepstow, Wales
Hi,
Will a regular fitting 939 heatsink fit on an AM2 cpu?
I want to use the same kind of heatsink that I use now on the new board when I get it.
I never use any heatsinks that you fix to the motherboard it's self, only the kind where you hook the one side(3 holes)over and the other side has the one or three holes and a lever.
Will those kind fit ok?
Thanks
