Sky 900 vs EE 900 vs BT 900
12 Jan 2003
Watford
Dear All
About to come to the end of my contract with Virgin, and want to move provider to FTTP, which is now in my area.
I have options with EE, or sky, or BT, all similar prices
Sky seem to suggest that on their 900 gigafast product, they have slower upload speeds than BT ?
Should I just go with the cheapest, are they all the same product, or are there technical differences in terms of speed/latency ?
R
Mehul
I'm with Sky 500mb. I and many other have had a lot of issues with using a VPN causing all sorts of issues, so I would avoid if you use VPN.
Can't get Zen?
Also do you really need 900? We went 500 and I'd say even that is overkill.
I downloaded a 70gb game on Steam in 20 minutes.
Can't get Zen?
Hiya
So its basically for my work, I need the best upload speed I can. Thats why I am looking at the 900 products. Will look at Zen, thank you
Mehul
Based on what?
Their peering, the fact that you get a 4G Backup if the net goes down for whatever reason, speed guarantee aswell.
Cuckoo is also probably a good option, they use TalkTalk Business for their network, so you're getting access to that without all the headache of having a business line.
And there's also no contract so you can leave at any time...
Fair point about the backup, but most people have mobile phones they can use as a hotspot and the switchover speed isn't all that fast. Also, EE are BT, and can work out cheaper if you're an EE mobile customer.
Cuckoo by default use CGNAT which can be extremely problematic.
To request a static IP address, use this page:
But the link doesn't work. Great start. :cry:
With a link that takes you to a generic contact us page, and not a form as suggested.
Weird I clicked it on an incognito tab and it worked, you can just go on there and search 'Can I get a static IP address?', and the same article should pop up.
I mean the link on the static IP page. £1 a month is also a bit much in order to circumvent CGNAT, that soon mounts up. Not everyone needs a static IP address so for a normal user to have to shell out to get around the well documented CGNAT issues that many see means it's not really an ISP I could recommend.
Ah right I see what you mean.
Yeah I do think they should just hand out IP's to everyone, it's a small cost for them which can cause complaints etc, especially with customers who aren't aware.
But at the same time I imagine they've already done that risk assessment, and they've seen that most customers won't really have issues with this hence why they have CGNAT defaulted?
Anyway if you know or are made aware that CGNAT is going to be a issue for you, you simply pay the extra £1/mo and then you're set.
By peering etc, do BT provider better latency/router etc - for somereason, on the same openreach product, BT are advertising higher speeds for DL and UL ?
The rate they can advertise is based on the averages being achieved by their users. A larger ISP with more people on the top tier product and routers that have software in them to monitor the speeds that the service is running at will have the data to back their claims up. There's no difference in the speeds that the services are provisioned at.
ISPs don't buy CGNAT boxes for fun, they do it because they do not have enough IPv4 addresses for the user base. Anybody who doesn't play games or host services will not be impacted by CGNAT as things like Zoom, Teams etc. will all work around it. £1/month for an IP address is, if anything, below the market rate when compared with other ISPs that charge.
Yeah, definitely, that's why they cost a decent amount vs /48 blocks that are handed out to each customer on IPv6 nowadays.
Yeah that was my point really, most people probably not affected by it, so they went with having CGNAT as default.
Then if someone needs it they can optionally pay the extra for it, I don't really see a massive issue with it, my point really was that I can imagine some confused customers wondering why their port forwards are not working.
I think it definitely needs to be regulated so that ISPs have to inform customers that they are buying a CGNAT connection, with a link to a page explaining the potential downfalls and the pricing to opt-out if available - imagine if you were sold a connection that could only support HTTP and HTTPS because it reverse proxied everything? It would work for the most part but it's not what anybody could define as an Internet connection.
If you're going to run CGNAT for IPv4 I really think it's inexcusable to not then have a working IPv6 deployment.
