Sky and RGB
Another quick one, what does scart control 'on' mean? I can see the picture change.
Also when I press the tv button on the sky remote it seems to go back to Pal, then when i press the Sky button on the remote the screen flicks and appears to go to RGB?
Thanks in advance
Thanks in advance
Scart control enables the Sky Box to switch the TV into 16:9 mode when true 16:9 broadcasts are present. It also allows the Sky Box to switch the TV over to AV1 when the Sky Box is switched on. Also, some TV's will not display an RGB picture without this setting switched on too.
When you press TV on the Sky Remote it does fall back to Pal. This is the same with all boxes and remotes.
