Sky BB and using your own router?
Yes it is from what I've heard, although don't go telling everyone you're using it or you'll have a problem on your hands. I watched a video/read up you need to enter a password to link your router onto your phone-line so you can have access to the internet through your own router without any problems.
Why on Earth do Sky force you to use their (poor) router anyway, seems a stupid idea to me. If they enable any decent layer 2 authentication in the future then it would make me not want to use them as an ISP. I hope that they keep it how it is so I can switch when my BT contract is up.
It makes it MUCH easier from a support point of view if you know they'll have one of only a few routers. Also it means they can pre-load all the login details onto the Router as well to save on calls helping to setup access.
But I dare-say only people who know what they're doing would change the router anyway.
Is there any way to put a Sky box (Sagem 2504) in bridge mode to use its modem only, and have all the routing work done by my proper router? I've a Buffalo WZR-HP-G300NH that has gigabit LAN and 300Mbps wireless going spare...
I have been doing this with BE for the past 5 years and have just moved into a flat that has a Sky connection.
Thanks!
OK got it all done now. Took a few hours but got there in the end. Performance has increased noticeably, as the WZR-HP-G300NH running the latest DD-WRT build is a nice, usable bit of kit.
I can't complain about the sync speed the 2504 gives in my new flat. However, its networking features are badly out of date, hence the integration of my WZR-HP-G300NH.
I've the WZR-HP-G300NH set up to use Google's DNS servers which seem to be working fine.
