Sky BB Speed
Homeplugs are working fine then.
Can't advise on anything else unless we get some router stats and know how far you are from the exchange.
That means not a lot!
Go to 192.168.0.1 in a web browser and take a look at the diagnostic information then show statistics.
http://192.168.0.1/sky_system.html
Router Statistics
System Up Time: 390:29:45
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time
WAN PPPoA 85431061 119868075 0 965 3432 390:28:33
LAN Up 23493028 14414436 0 388519 17134 390:29:45
WLAN Up 43985111 37886751 0 7541 5187 390:29:22
Broadband Link Downstream Upstream
Connection Speed 13408 kbps 958 kbps
Line Attenuation 27.0 dB 14.5 dB
Noise Margin 4.9 dB 8.8 dB
Poll Interval:
Seconds (at least 3s):
Set Interval Stop
200Mbps is the maximum speed of the homeplugs. Your internet connection is only 13Mbps. Guess which one is the limiting factor?
You'll get around 100Mbps on your internal network for transferring files etc - limited by the 100Mbps ports on your Sky router.
How can you tell from looking at that ?
I'm not questioning you, just interested.
ADSL line speeds drop with distance. I'm 300m from the exchange and get 22MB, you will get less being further away.
Google ADSL2+ speed graph or ADSL2+ line speed calculator. You can feed in some of the numbers above and it will give a theoretical maximum, you'll get a bit less as no line is perfect.
