- 26 Feb 2007
- Blackpool
Right i noticed o nthe back of my Sky + box that there is S Video output. Could i buy an S Video cable and use that instead of SCART to send the picture to my 40" Samsung M87 tele?
SCART is terrible quality on my 1080p tele? is there ay other way of getting a sharper picture like SCART to HDMI or something? or SCART to component?
Make sure you have the Sky+ box set to Scart RGB mode, rather than Scart Composite. Makes a massive difference in picture quality.
Scart RGB is just as good as componant for an interlaced PAL signal, and as Sky+ doesnt support progressive, thats the best you can get.
S-Video is considerably lower quality than Scart in RGB mode.
Scart RGB mode is also slightly more tolerant of cheap scart cables, just as long as its a fully wired cable. (Otherwise it wont work at all in rgb mode). For SD PAL channels, Scart RGB's all you need, obviously make sure you plug it in to an RGB compliant scart socket on the TV. Not all sockets on all TV's have rgb enabled.
Only when you go to SkyHD does HDMI make any improvement at all, and of course the SkyHD box has native support for HDMI anyway![]()
Do you mean put the SCART setting to RGB in the Sky settings interface in the Sky Guide?
its just when i use SCART i get Wavy lines on my tele. I was told it was the SCART cable and it was bad qaulity by Martin Dawes (samsung contracted engineers). But my dad has the same tele and SCART and his doesnt do it.![]()
MY settings have always been RGB on sky box. Think ill just buy a HD box for the HDMI.
What about running the Sky+ through a DVD Recorder with HDMI upscaling, I think the Panasonic ones can upscale devices through Scarts too.
