Sky broadband help (connection problem)
  • Thread starter Thread starter Pho
  • Start date Start date
Pho
Pho
18 Oct 2002
Derbyshire
I've been trying to set-up someones Sky broadband tonight and am having problems. The internet connection appears to work - I can ping websites and even access my own PC remotely (remote desktop) but if I try and use the browser it doesn't work. I've tried this on two PCs and a Laptop and all of them do the same thing - so I can pretty much rule out malware / spyware (I even tried it in safe mode). I've even tried accessing websites by IP and that doesn't work either.
The sky start page (skybroadband.com) appears to half load. If I view the source of the page as it's connecting I can see about 40 lines downloaded but nothing else.
I'm using the Sky branded DG834G. Does anyone have any ideas? I'm stumped.
Thanks.
Pho said:
I've been trying to set-up someones Sky broadband tonight and am having problems. The internet connection appears to work - I can ping <SNIP>
Thanks.
You have rebooted the router, tried proxy settings, firewall e.t.c?
What package are they on , connect or base mid max. been a couple of big outages today and last night.
I've rebooted the router a couple of times - according to the status page on the router it's connected and the logs don't show anything unusual. I forgot to check for the Windows firewall but I disabled McAfee.
Dave- I'm not sure of their package, but they are synced at 6mb so I'd assume either Mid or Connect.
Do you happen to have a Sky service status link? I couldn't see one.
There isn't any service links, you could ask at the skyuser forum.
Google skyuser.
