- 3 Oct 2004
- Biggin Hill
Hi
I have a sky q hub on sky superfast and the connection over wifi drops for around 10 seconds to a minute evey so often and signal strength to some rooms is poor.
I was thinking of upgrading to sky ultrfast, as I believe I get the new Sky Broadband router (please correct me if wrong) as I believe the higher bandwidth and better router will really help.
Is there a way of working out what is causing the drop out problem? I have a lot of wifi devices connected, mainly wifi plugs, would that cause an issue?
Also, if I was to buy the new sky broadband router, would I be able to use that with my current setup to perhaps resolve the issue?
Any help or guidance would be gratefully received
