Sky Broadband technical support
7 Mar 2005
My old folks signed up to sky braodband a few months ago. All was good until 2 days ago when their connection went down.
It took 22 minutes to a tech support muppet (could barely understand her accent and visa versa) to explain to them that I could get into the router settings via the wireless option and the sky test was coming up with an error code 200 or 300 (it varied)
She then asked me to plug the network cable between the PC and the router as it may be a wireless problem.
How is that a wireless problem if I can talk to the router? She then came up with the excuse that 'we don't support belkin wireless adaptors' to which I pointed out that the adapter was working fine as I could access the router settings. She tried telling me this about 20 times before I started to loose my patience.
In the end, she accepted that it was a problem at Sky's end and my old folks have to wait 5 working days for a potential solution to the problem.
No settings had been changed overnight and strangely all 3 green lights on the router are lit.
Has anyone else come across this problem? If so how long did it take to get through to the inept support staff (almost on par with NTL but wihout the 3 days on hold)? What was the outcome?
Many thanks!
I do not know the error code you are getting but see if can get some extra info so you can go back to Sky Tech with
IS the router connecting to Sky, are you getting an IP address on the router from them ?
If you are then try to ping IP address and WWW address ? try pinging 212.58.224.55 also try to ping www.bbc.co.uk
The router isn't connecting to Sky. There is no IP address in the router settings. Just a mac address. All other fields are blank (bar one but iirc it's the 255.255 etc setting).
i get this occasionally, mainly error code 300 where on connection status it says LCP is down.
Either a router reboot solves this, or it'll just start working ok the next day on its own. I really think its a sky network thing, maybe due to high number of users etc at a time, as my line stats are generally fine (downstream 8190kbps atten: 25.5db SNR 15.5db, upstream 396kbps Atten: 14.9 SNR: 24.0db)
I think its just sheer uptake of their service, i didnt expect a problem free ride to be honest when i joined.
