Probly not is the answer. The T&Cs state you must use the supplier router, also the username/password is hardcoded into the router. Coupled with the custom firmware you can't just copy and paste it out.
Sky have changed router in the last few weeks. The old router was a Netgear DG834GT with custom firmware which some enterprising peeps hax0red so you can get the details. The new custom made to Sky's requirements router has no workaround at the moment.
Nothing to stop you just using the Sky router as modem and connecting your existing router to that. Bit complicated but do-able...
