Sky DSL router change (N55U)
18 Oct 2002
Hereford
Hi guys
Got tired of my old Sky supplied Sagem's wifi signal being rubbish and the connection getting more unreliable so grabbed an Asus DSL-N55U from the MM to replace it.
Anyone unaware the Sky T&C's tell you to use their supplied router only & they don't supply you with the username & pass. There are tools online to lookup/generate the username & pass you need (generated from router type and MAC). I looked up/generated these online with a link from the skyuser forums.
Setup the N55U yesterday very basic setup & did nothing special, apart from clone the MAC of the old Sagem (unsure if required, wouldn't seem to connect until I did).
Appeared to work and was rock solid all day. Went to bed and woke up this morning with it disconnected and it doesn't want to reconnect for some reason. I've changed microfilter and it still won't reconnect...
Log into the router and if I click on 'Disconnected' it takes me back to the Easy Setup and looks to have lost the login details???
System log shows this (after a reboot so lost the log from last night):
Jan 1 00:00:12 syslogd started: BusyBox v1.17.4
Jan 1 00:00:12 kernel: The CPU feqenuce set to 500 MHz
Jan 1 00:00:12 kernel: CPU revision is: 0001974c
Jan 1 00:00:12 kernel: Determined physical RAM map:
Jan 1 00:00:12 kernel: memory: 08000000 @ 00000000 (usable)
Jan 1 00:00:12 kernel: Built 1 zonelists. Total pages: 32512
Jan 1 00:00:12 kernel: Primary instruction cache 64kB, physically tagged, 4-way, linesize 32 bytes.
Jan 1 00:00:12 kernel: Primary data cache 32kB, 4-way, linesize 32 bytes.
Jan 1 00:00:12 kernel: cause = c0808000, status = 11000000
Jan 1 00:00:12 kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Jan 1 00:00:12 kernel: calculating r4koff... 001e8480(2000000)
Jan 1 00:00:12 kernel: CPU frequency 500.00 MHz
Jan 1 00:00:12 kernel: Using 250.000 MHz high precision timer.
Jan 1 00:00:12 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:12 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:12 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:12 kernel: RALINK_PCI_PCICFG_ADDR = 0
Jan 1 00:00:12 kernel: *************** Ralink PCIe RC mode *************
Jan 1 00:00:12 kernel: registering PCI controller with io_map_base unset
Jan 1 00:00:12 kernel: 2->[1][0][0][30]=0
Jan 1 00:00:12 kernel: 5->[1][0][0][30]=fffffffe
Jan 1 00:00:12 kernel: 5->[1][0][0][30]=0
Jan 1 00:00:12 kernel: BAR0 at slot 0 = 0
Jan 1 00:00:12 kernel: bus=0, slot = 0x0
Jan 1 00:00:12 kernel: P2P(PCI) 0x00 = 08021814
Jan 1 00:00:12 kernel: P2P(PCI) 0x04 = 00100007
Jan 1 00:00:12 kernel: P2P(PCI) 0x08 = 06040001
Jan 1 00:00:12 kernel: P2P(PCI) 0x0c = 00010014
Jan 1 00:00:12 kernel: P2P(PCI) 0x10 = 00000000
Jan 1 00:00:12 kernel: P2P(PCI) 0x14 = 20100000
Jan 1 00:00:12 kernel: P2P(PCI) 0x18 = 00010100
Jan 1 00:00:12 kernel: P2P(PCI) 0x1c = 000000f0
Jan 1 00:00:12 kernel: P2P(PCI) 0x20 = 20002000
Jan 1 00:00:12 kernel: P2P(PCI) 0x24 = 0000fff0
Jan 1 00:00:12 kernel: P2P(PCI) 0x28 = 00000000
Jan 1 00:00:12 kernel: P2P(PCI) 0x2c = 00000000
Jan 1 00:00:12 kernel: P2P(PCI) 0x30 = 00000000
Jan 1 00:00:12 kernel: P2P(PCI) 0x34 = 00000040
Jan 1 00:00:12 kernel: P2P(PCI) 0x38 = 00000000
Jan 1 00:00:12 kernel: P2P(PCI) 0x3c = 00040100
Jan 1 00:00:12 kernel: res[0]->start = 0
Jan 1 00:00:12 kernel: res[0]->end = 1ffffff
Jan 1 00:00:12 kernel: res[1]->start = 20100000
Jan 1 00:00:12 kernel: res[1]->end = 2010ffff
Jan 1 00:00:12 kernel: res[2]->start = 0
Jan 1 00:00:12 kernel: res[2]->end = 0
Jan 1 00:00:12 kernel: res[3]->start = 0
Jan 1 00:00:12 kernel: res[3]->end = 0
Jan 1 00:00:12 kernel: res[4]->start = 0
Jan 1 00:00:12 kernel: res[4]->end = 0
Jan 1 00:00:12 kernel: res[5]->start = 0
Jan 1 00:00:12 kernel: res[5]->end = 0
Jan 1 00:00:12 kernel: bus=1, slot = 0x0
Jan 1 00:00:12 kernel: dev III(PCIe) 0x00 = 30911814
Jan 1 00:00:12 kernel: dev III(PCIe) 0x04 = 00100000
Jan 1 00:00:12 kernel: dev III(PCIe) 0x08 = 02800000
Jan 1 00:00:12 kernel: dev III(PCIe) 0x0c = 00000000
Jan 1 00:00:12 kernel: dev III(PCIe) 0x10 = 20000000
Jan 1 00:00:12 kernel: dev III(PCIe) 0x14 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x18 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x1c = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x20 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x24 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x28 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x2c = 30911814
Jan 1 00:00:13 kernel: dev III(PCIe) 0x30 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x34 = 00000040
Jan 1 00:00:13 kernel: dev III(PCIe) 0x38 = 00000000
Jan 1 00:00:13 kernel: dev III(PCIe) 0x3c = 000001ff
Jan 1 00:00:13 kernel: res[0]->start = 20000000
Jan 1 00:00:13 kernel: res[0]->end = 2000ffff
Jan 1 00:00:13 kernel: res[1]->start = 0
Jan 1 00:00:13 kernel: res[1]->end = 0
Jan 1 00:00:13 kernel: res[2]->start = 0
Jan 1 00:00:13 kernel: res[2]->end = 0
Jan 1 00:00:13 kernel: res[3]->start = 0
Jan 1 00:00:13 kernel: res[3]->end = 0
Jan 1 00:00:13 kernel: res[4]->start = 0
Jan 1 00:00:13 kernel: res[4]->end = 0
Jan 1 00:00:13 kernel: res[5]->start = 0
Jan 1 00:00:13 kernel: res[5]->end = 0
Jan 1 00:00:13 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:13 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 00:00:13 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:13 kernel: Amd/Fujitsu Extended Query Table at 0x0040
Jan 1 00:00:13 kernel: mtd: partition "linux" extends beyond the end of device "Ralink SoC physically mapped flash" -- size truncated to 0x7b0000
Jan 1 00:00:13 kernel: mtd: partition "rootfs" extends beyond the end of device "Ralink SoC physically mapped flash" -- size truncated to 0x6b9280
Jan 1 00:00:13 kernel: mtd: partition "rootfs" doesn't start on an erase block boundary -- force read-only
Jan 1 00:00:13 kernel: RT3xxx EHCI/OHCI init.
Jan 1 00:00:13 kernel: pcie_portdrv_probe->Dev[1814:0802] has invalid IRQ. Check vendor BIOS
Jan 1 00:00:13 kernel: assign_interrupt_mode Found MSI capability
Jan 1 00:00:13 kernel: GPIO MODE: 189f
Jan 1 00:00:13 kernel: Ralink gpio driver initialized
Jan 1 00:00:13 kernel: rtl8367r_init...
Jan 1 00:00:13 kernel: switch IC = CHIP_RTL8367R_VB, SDK = V1.2.6
Jan 1 00:00:13 kernel: rdm_major = 254
Jan 1 00:00:13 kernel: GDMA1_MAC_ADRH -- : 0x00000000
Jan 1 00:00:13 kernel: GDMA1_MAC_ADRL -- : 0x00000000
Jan 1 00:00:13 kernel: Ralink APSoC Ethernet Driver Initilization. v2.0 256 rx/tx descriptors allocated, mtu = 1500!
Jan 1 00:00:13 kernel: GDMA1_MAC_ADRH -- : 0x000014da
Jan 1 00:00:13 kernel: GDMA1_MAC_ADRL -- : 0xe9fa77ec
Jan 1 00:00:13 kernel: PROC INIT OK!
Jan 1 00:00:13 kernel: u32 classifier
Jan 1 00:00:13 kernel: OLD policer on
Jan 1 00:00:13 kernel: Netfilter messages via NETLINK v0.30.
Jan 1 00:00:13 kernel: nf_conntrack version 0.5.0 (1024 buckets, 8192 max)
Jan 1 00:00:13 kernel: ipt_time loading
Jan 1 00:00:13 kernel: ip_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:13 kernel: net/ipv4/netfilter/tomato_ct.c [Dec 18 2012 11:25:43]
Jan 1 00:00:13 kernel: ip6_tables: (C) 2000-2006 Netfilter Core Team
Jan 1 00:00:13 kernel: VFS: Mounted root (squashfs filesystem) readonly.
Jan 1 00:00:13 kernel: Warning: unable to open an initial console.
Jan 1 00:00:13 kernel: phy_tx_ring = 0x013a2000, tx_ring = 0xa13a2000
Jan 1 00:00:13 kernel: phy_rx_ring = 0x013d7000, rx_ring = 0xa13d7000
Jan 1 00:00:13 kernel: CDMA_CSG_CFG = 81000007
Jan 1 00:00:13 kernel: GDMA1_FWD_CFG = C0710000
Jan 1 00:00:13 kernel: wan_stb_x=0
Jan 1 00:00:13 kernel: ethernet_wan_x=0
Jan 1 00:00:13 kernel: LAN: P1,P2,P3,P4 DSLWAN: P0
Jan 1 00:00:13 kernel: set switch ic to SVLAN
Jan 1 00:00:13 kernel: configure_dslwan_vlan(1, 01, 01, 01)
Jan 1 00:00:13 kernel: configure_dslwan_vlan(2, 1e, 1e, 1e)
Jan 1 00:00:13 kernel: configure_dslwan_vlan(3, 00, 00, 00)
Jan 1 00:00:13 kernel: configure_dslwan_vlan(4, 00, 00, 00)
Jan 1 00:00:13 kernel: rt2860v2_ap: module license 'unspecified' taints kernel.
Jan 1 00:00:13 kernel: === pAd = c0054000, size = 810064 ===
Jan 1 00:00:13 kernel: <-- RTMPAllocAdapterBlock, Status=0
Jan 1 00:00:13 kernel: === pAd = c02d4000, size = 613560 ===
Jan 1 00:00:13 kernel: pAd->CSRBaseAddress =0xc0120000, csr_addr=0xc0120000!
Jan 1 00:00:13 kernel: Algorithmics/MIPS FPU Emulator v1.5
Jan 1 00:00:13 kernel: NTFS support included
Jan 1 00:00:14 kernel: Built_for__asus_n56u_2011-11-22
Jan 1 00:00:14 kernel: RX DESC a70b1000 size = 2048
Jan 1 00:00:14 kernel: <-- RTMPAllocTxRxRingMemory, Status=0
Jan 1 00:00:15 kernel: Key1Str is Invalid key length(0) or Type(0)
Jan 1 00:00:15 kernel: Key2Str is Invalid key length(0) or Type(0)
Jan 1 00:00:15 kernel: Key3Str is Invalid key length(0) or Type(0)
Jan 1 00:00:15 kernel: Key4Str is Invalid key length(0) or Type(0)
Jan 1 00:00:15 kernel: 1. Phy Mode = 9
Jan 1 00:00:15 kernel: 2. Phy Mode = 9
Jan 1 00:00:15 kernel: 3. Phy Mode = 9
Jan 1 00:00:15 kernel: ^[[mAntCfgInit: primary/secondary ant 0/1
Jan 1 00:00:15 kernel: ^[[mRTMPSetPhyMode: channel is out of range, use first channel=0
Jan 1 00:00:15 kernel: MCS Set = ff ff 00 00 01
Jan 1 00:00:15 kernel: SYNC - BBP R4 to 20MHz.l
Jan 1 00:00:17 kernel: =====================================================
Jan 1 00:00:17 kernel: Channel 1 : Dirty = 0, False CCA = 237, Busy Time = 6836, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 2 : Dirty = 0, False CCA = 170, Busy Time = 5099, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 3 : Dirty = 0, False CCA = 71, Busy Time = 1323, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 4 : Dirty = 0, False CCA = 11, Busy Time = 626, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 5 : Dirty = 0, False CCA = 63, Busy Time = 2063, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 6 : Dirty = 0, False CCA = 257, Busy Time = 7889, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 7 : Dirty = 0, False CCA = 174, Busy Time = 5285, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 8 : Dirty = 0, False CCA = 26, Busy Time = 767, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 9 : Dirty = 0, False CCA = 19, Busy Time = 1549, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 10 : Dirty = 0, False CCA = 278, Busy Time = 3045, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 11 : Dirty = 0, False CCA = 1055, Busy Time = 18211, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 12 : Dirty = 0, False CCA = 557, Busy Time = 10448, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Channel 13 : Dirty = 0, False CCA = 855, Busy Time = 22081, Skip Channel = FALSE
Jan 1 00:00:17 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 1
Jan 1 00:00:17 kernel: Min Dirty = 4294967295
Jan 1 00:00:17 kernel: ExChannel = 0 , 0
Jan 1 00:00:17 kernel: BW = 40
Jan 1 00:00:17 kernel: Main bssid = 14:da:e9:fa:77:e8
Jan 1 00:00:17 kernel: <==== rt28xx_init, Status=0
Jan 1 00:00:17 kernel: 0x1300 = 00064380
Jan 1 00:00:18 kernel: RX DESC a719f000 size = 2048
Jan 1 00:00:18 kernel: <-- RTMPAllocTxRxRingMemory, Status=0
Jan 1 00:00:18 kernel: Key1Str is Invalid key length(0) or Type(0)
Jan 1 00:00:18 kernel: Key2Str is Invalid key length(0) or Type(0)
Jan 1 00:00:18 kernel: Key3Str is Invalid key length(0) or Type(0)
Jan 1 00:00:18 kernel: Key4Str is Invalid key length(0) or Type(0)
Jan 1 00:00:18 kernel: 1. Phy Mode = 8
Jan 1 00:00:18 kernel: 2. Phy Mode = 8
Jan 1 00:00:18 kernel: 3. Phy Mode = 8
Jan 1 00:00:18 kernel: RTMPSetPhyMode: channel is out of range, use first channel=0
Jan 1 00:00:18 kernel: MCS Set = ff ff ff 00 01
Jan 1 00:00:18 kernel: SYNC - BBP R4 to 20MHz.l
Jan 1 00:00:19 kernel: =====================================================
Jan 1 00:00:19 kernel: Channel 36 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:19 kernel: Channel 40 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:19 kernel: Channel 44 : Dirty = 0, False CCA = 0, Busy Time = 0, Skip Channel = FALSE
Jan 1 00:00:19 kernel: Channel 48 : Dirty = 0, False CCA = 0, Busy Time = 98, Skip Channel = FALSE
Jan 1 00:00:19 kernel: Rule 1 CCA value : Min Dirtiness (Include extension channel) ==> Select Channel 36
Jan 1 00:00:19 kernel: Min Dirty = 4294967295
Jan 1 00:00:19 kernel: ExChannel = 0 , 0
Jan 1 00:00:19 kernel: BW = 40
Jan 1 00:00:19 kernel: Main bssid = 14:da:e9:fa:77:ec
Jan 1 00:00:19 kernel: <==== rt28xx_init, Status=0
Jan 1 00:00:19 kernel: 0x1300 = 00064380
Jan 1 00:00:19 stop_nat_rules: apply the redirect_rules!
Jan 1 00:00:19 WAN Connection: Ethernet link down.
Jan 1 00:00:19 DSL-N55U: start httpd
Jan 1 00:00:19 kernel: set watchdog pid as: 453
Jan 1 00:00:19 disk monitor: be idle
Jan 1 00:00:20 kernel: eth2.1.1: Setting MAC address to 14 da e9 fa 77 e8.
Jan 1 00:00:20 kernel: VLAN (eth2.1.1): Setting underlying device (eth2.1) to promiscious mode.
Jan 1 00:00:23 kernel: SQUASHFS error: lzma returned unexpected result 0x1
Jan 1 00:00:23 kernel: SQUASHFS error: Unable to read page, block 415955, size 56f9
Jan 1 00:00:23 kernel: SQUASHFS error: Unable to read page, block 48dbeb, size 5246
Jan 1 00:00:23 kernel: SQUASHFS error: Unable to read page, block 3f3946, size 55e1
Jan 1 00:00:24 kernel: SQUASHFS error: Unable to read page, block 48dbeb, size 5246
Jan 1 00:00:24 kernel: SQUASHFS error: lzma returned unexpected result 0x1
Jan 1 00:00:24 kernel: SQUASHFS error: Unable to read page, block 492e31, size b22
Jan 1 00:00:24 kernel: SQUASHFS error: Unable to read page, block 3f3946, size 55e1
Jan 1 00:00:32 kernel: nf_conntrack_rtsp v0.6.21 loading
Jan 1 00:00:32 kernel: nf_nat_rtsp v0.6.21 loading
Jan 1 00:00:32 zcip client: configured 169.254.179.151
Firmware is 3.0.0.4.335
Worth changing? A hard reset seems to solve the problem temporarily.
I've found a cold reboot of the router 'solves' it. Obviously when it's working I don't power it down so I don't know the frequency of it reoccurring ;)
