SKY Fiber + Draytek Vigor 130 + USG 3P Help?
24 Nov 2019
So i just decided to unifi my home using a draytek modem the vigor 130 i've set up all the unifi gear and got all that working using my ISP combo unit and now that i want to switch over to my new modem (Vigor 130) im a little stuck, For refrence im with SKY so i heard its abit trickey im also using a USG 3P so i have read that you need to put the modem in bridge mode(which i have done) so i have tried that but still unable to get the network working using my new modem so i was wondering if anyone has or know if they could help me get this working it would be much appreciated and thank you.
You’ll need to configure the router to make the connection using DHCP option 61 (aka MER) rather than PPPoE. I don’t know if that router supports it or not.
If you can get this working then it's going to be via editing the JSON config file that the USG loads, removing the major benefit of running a UniFi system.
