Morning All,
I have moved from BT Inifinity to Sky fibre unlimited. Speeds and connectivity with the included SR102 modem/router are fine (37Mbps /10Mbps). I am trying to set up my Openreach modem and Asus router so that I can remove the SR102 altogether.
So far I have extracted my username and password using wireshark and tried the calculation method. On both occasions the password comes out in a slightly different format to what I expected based on other posts:
Using wireshark: LNNLNLLNNNNL@skydsl|NNNLLNLN (all letters in this instance are lowercase)
Using the password calculator the password is displayed as: LNLLll+lNLLLLll Although the default WiFi Channel and SSiD are returned blank.
I have tried using ‘ around the username and password combination and using the password generated from Wireshark and the calculator (both the bit before and after the ‘+’ sign).
The MAC address from wireshark matches the address displayed in the SR102 settings. I have entered the MAC address of the SR102 into the Asus router and enabled MAC spoofing as it appears from the SR102 settings MER is active.
I have connected the Asus WAN port to the BT modem LAN1 connection and have a DSL light. I have not accessed or changed the Openreach modem whatsoever since it was used for BT. As a test I plugged in the BT modem and connected it to the SR102 (i.e. faceplate - Openreach modem - SR102 - PC). The BT modem appears to be working fine as I could connect to the internet no problem - could I be misinterpreting this?
I have tried setting up the Asus with the latest firmware from Asus and the Merlin variant – without success.
I suspect my authentications settings aren’t right or I’ve missed another step. I anyone has any suggestions I’d be very grateful. If you need any further information or clarification let me know. If there's anyone with an Asus router who's successfully swapped out their Sky modem/router it would be good to hear from you! Thanks
