SKY Fibre Help
18 Oct 2002
Aberdeen
Hi
I have a quick question, I'm pretty sure my problem is with my Sr101 router
can I buy a Sr102 router from ebay and plug it in
will it work
No experience with the newer ones. Just didn't like the older ones. I needed certain features like QOS, VPN server, Multiple Guest Networks etc. which the Sky hubs didn't have.
Yeah I picked up a SR102 black one from Gumtree 2nd hand (£5), and its working fine, i did look at the Sky Q on ebay but i didnt want to pay the stupid money. My Line re-synced at 34999 so im happy with that. Im looking at a netgear wifi router to use alongside the sky black box
True, yes. But as I've been with Sky for the past 20 years my original statement still stands.
You advised the OP to stay away from Sky routers because:
  • An old version of the router didn't have some features you needed (which 99.9% of people don't need)
  • That you have been with Sky for 20 years
Internet at its best.
Think you need to re-read my post. I used the words "I" and "Personally".
