Sky HD box ?
Why would you use a SCART.
Hook up the TV with the HDMI lead and hook up an amp via the optical out.
I have mine set up this way. I just turn the TV down and crank up the amp.
If it's a movie in 5.1 then all the amps pekers come into play..
Turn the amp right up and feel the sound !!!!
Yes the sky box outputs all audio and video simultaneously.
Would using two different connections on two different types of amps give a little lag and cause a slight sync problem ?
Only one way to find out.
Be interesting to find out if you get this working.
Thanks MissChief
I don't think there will be any lag problems. I used to use the stereo amp before I got the AV amp and there were no sync issues with the video output.
Whoosh..... the sound of the question and answers in this thread going right over your headSky HD box ?
lol... just kidding you along
