it's better
you can use it as a tv guide, remote record, as well as change the channels, pause, rewind, etc, etc.
in fact i use the app more than i do the remote.
it has highlights for the day (best shows on that day), shows similar programmes to the ones your watching and when they are on.
it also tells you all the different viewings for a programme so you can record the ones at 2am, etc so you can record something else during the day, etc.
also has a brilliant search function as well, can search by actor, director or name of tv show or movie, etc.
the remote is now a thing of the past.
