Hi
I have the black sky hub on the thirty something fibre package.
I currently have 15 devices on the network and the hub has stopped allowing new devices to connect, they either time out or give an auth error.
If I remove one of the connected devices, I can connect one of the unconnected devices ok, and if I remove two I can connect two more etc but I cannot get more than 15 at once.
I believe the hub supports 250 connections. I've tried a reboot. As a short term work around I will plug an old router in as an additional access point but obviously I want to sort this out.
Tried searching some of the sky forums but no joy.
Any ideas? Not much to go on, I know.
Cheers
Cheers
