I live between two places.
Location 1: I have vDSL (80/20) via Plusnet and I have a BT Openreach modem with an ASUS RT-AC68U router using Merlin firmware. The set up is great, I get great wireless coverage, the uptime is great and I use the OpenVPN feature quite a lot on it.
Location 2: standard ADSL2+ and I have a Sky SR102 router. To put it frankly, it is a POS and needs replaced. Wireless coverage is very poor. It is limited to the 2.4GHz band and struggles to cover a rather small flat. The contract runs until next year, so changing provider at the moment is out of the question. I assume I can extract the username and password quite easily from the router, what are my next options?
Option 1- Keep the Sky SR102, get something like the ASUS RT-AC68U or the Apple Airport Extreme and put the new router in access point mode
Option 2- Replace the Sky SR102 with a dedicated modem (any recommendations?) and use either the ASUS or the Apple router as above
Option 3- Get an all in one solution that works with Sky ADSL
In an ideal world, I'd get the ASUS DSL-AC68U, but with the very poor reviews, I'm inclined to ignore that option.
I'm tempted to go for either option 1 or 2 but what are your thoughts?
