You'll need to provide more information than that, or no one will be able to help you. There's a sticky topic at the top of the forums that you may find useful.
The line code won't necessarily change from ADSL2+ to G.DMT with changing the router.
What you need to do is connect the sky router and post your line stats, then do the same with
Your new router.
Is the chipset in your DGN1000 the same as the sky router?
What sky router is it? The new wireless N one?
