Sky on second telly without multi-room?
21 Oct 2008
Mooching... in your house
ok so we've bought a shiny new telly and upgraded to Sky+ HD in the lounge, but would like to be able to watch sky in the conservatory on an old (but still trusty) 26" samsung...
now i originally thought maybe there is something I could do with the old Sky+ box to make this work, but after a bit of investigation realised that actually, I cant...
So then I started looking at something like this:
so let me get this straight... with this I can just plug it in a steal the signal from the Sky HD box in the lounge? and it will be able to view the recorded stuff etc etc? would I also not need to plug in a crappy little aerial?
I'm assuming that by using it from here you can't use the main box (not a problem since it'll be used by my wife when i'm on the ps3 no doubt :p)
So yeah, just after a bit of advice as to what I can achieve with this and if its the right tool for the job?
ahh rubbish I think i've got it wrong, this would need wiring up to the main box via coax?
that'd be a right bitch of a job in my house :(
might have to have a rethink... any advice? any way to do this wirelessly maybe?
how do you plug your TV into the sky box?
Cause a wireless TV sender would work if its SCART or similar (Basically not HDMI).
Plug transmitter into Sky/TV connection, receiver into back of other telly. Job done.
well, I would plug the Sky HD box into the telly with HDMI, does this maybe mean I can't do it?
I have been looking around and something like a Philex Compact Flat Wireless AV Sender looks pretty good - can transmit the IR signals back as well so you get control with the sky remote :)
Anyone got any recommendations about which of the many MANY senders is good to get? and also is the quality ok or do you loose a lot?
It wouldnt be HD, obv, but that isnt an issue.
My concern is more that you wont get anything displayed as its all being output through HDMI, and there's no senders i've seen that have a HDMI base station. So i think this is a dead end tbh. The old ones i have used (SCART) worked fine actually, picture was as good as the source (ish), did have issues with wireless internet & microwaves though...
I'm using a philips video sender and pick it up in the bedroom and out in the garage. Picture is fairly good...
Ive used one of these before and it was crap. You need a run of coax all the way to your 2nd tv and I found the ir eye was very iffy. Maybe our run of cable was too long.
so it would seem that using coax is the only proper way to do it then, i assume theres no problem outputting the main a/v to the telly via HDMI and having a second signal piped out through one of the coax sockets?
He's using HDMI, and unless you can get sky to output over SCART and HDMI simultaneously that isnt going to work.
Yep - IIRC you can't use HDMI and SCART simultaneously. Your only other option really would be a HDMI splitter but then you'd still need a magic eye to be able to change channels!
I use a magic eye and it's brilliant. Does everything the box does. Just make sure you get one with the hd+ remote. Really is the best way and running a coax really isn't that hard. run it around the top of the skirting board and drill a hole through walls.
