Sky plus magic eye problem?
18 Oct 2002
Earth
Hi all
I've just bought a sky plus remote and a magic eye.
I've plugged the magic in the back of the tv and that feed is a direct feed to the back of my sky plus box to the RF2 out socket.
But i can't seem to get it to work at all?
I've tried the change over and that works fine in the main room with the box but not in the other room with the magic eye?
I'm pretty sure in saying theres nothing in the sky plus set up i need to change is there?
Any other ideas please?
Thank you.
It'll probably be because the RF2 power isn't switched on...
Press Services > 4 > 0, 1, Select (press them in succession, this opens the Installer menu)
Then go in to RF Outlets and set 'RF Outlet Power Supply' to On, then 'Save New Settings.
Should fix it :)
Should fix it :)
Thank very much works fine now :D
