- 25 May 2010
Hi guys
Hope this is the right section. Basically I'm trying to assign a static IP to my laptop using the IP reservation function in the router settings. Once I've reserved an IP for it outside the range that other devices have their's assigned from do I need to manually input the information on the network connection properties box (vista), or can I leave the setting on "obtain an IP address automatically" because it will always be assigned the same one? I'm doing this so I can use port forwarding.
Thanks for the help.
