sky + to PC
You can use a PC TV tuner card for this...(Or any card with video in should work.But a tv tuner card will normally be a lot easyer to use)
(I used to use my 9800pro all in wonder to do this before i sold it. :( )
jmahoney said:
what connection do you need ??
I was only using the normal analog coax cable in went i had my 9800pro aiw...
(But you get a better picture by using the Composite video in/audio in...)
If your thinking of using a TV tuner card..Check what video in connections it has..and that it has recording/capture software with it.
