Sky TV bluescreen
25 May 2013
Kent.
Apologies if this isn't the right place but seemed most fitting to my issue.
I was watching tv earlier on Sky, Discovery all well and good. Turned the tv and box off and came back later to watch a film.
I have a constant blue screen showing now. Turning off the tv and box and turning back on has not solved it. I don't think I've pushed a random button accidentaly that would cause this.
Any ideas?
I can reset it but not sure if that's going to complicant things with setting it up again or would a reset just be like on a PC to restart it..?
I'm clueless about these sorry I just watch it.
Do you get any messages at all? Any Sky TV fault screen always has a message so if it's completely blue it sound like the TV may be on the wrong source/input.
No, when I select a channel it shows at the bottom as normal, but apart from that is a pure blue screen. No error messages are visible and no cables have been touched.
I'm thinking it is an output issue most likely.
