Sky TV on a PC
JEB
JEB
19 Oct 2002
Caithness, Scotland
Need some advice please.
I have sky in the house. I want to watch Sky on my PC in my office as well, but not through Sky go as my internet connection is very poor.
If I run a coax TV point onto the office and link my Sky\Roof ariel with a splitter\booster, is it possible to use something like a USB TV tuner like a Hauppauge Wintv Nova-td - Dvb-t Tuner Device, plugged into my PC, and the extended TV point, to watch Sky on my PC.
Wasn't sure of the USB tuner would only pick up Freeview, or if it would also pick up the channel to display a Sky picture as well?
Probably not explained that very well, but if this won't work what's the best way to get a Sky signal through to watch on my PC? Cheers
You can get wireless senders but they're pretty flakey and can interfere with wifi. You can run a cable from the back of the Sky box if your PC has a TV Card.
Very simple
I take it your have a cable feed already from roof aerial to the room the sky box is in?
If so you plug that into the rf in and then there will be two rf outs which you run another cable feed from one of those (rf2 is best you can use magic eye with that to control from office).
with the way i just suggested you wont need to use any signal booster or splitters
your pc will need an analogue turner or hybrid like the link below (with hybrid you can get freeview and the sky channel)
http://www.overclockers.co.uk/showproduct.php?prodid=GX-014-CP&groupid=701&catid=1915&subcat=169
it should do yes, but I don't think you'll be able to change the channel.
Cheers - not too worried re being able to change the channel in the office. It'll be on Sky Sports 99.999% of the time :-) Thanks again for the advice.
I do this using a Slingbox, also allows me access to it while away from home. Quality, even over the local network, is not brilliant but ok for a small window.
