hey i just got the sky wireless router but i want it to connected my wireless router to my current IP address (plusnet) i heard you cant do that and another problem is that everytime i press ://192.168.0.1 nothing comes up
How do you do that then what the password for 192.168.0.1Hi, you are putting the HTTP before the router IP are you, as I have the netgear one from sky and it is definately 192.168.0.1 to access it.
Anthony
yea i have got thatonce you type 192.168.0.1 is there a pop up box asking for user name and password, if so its usually:
Username: Admin
Password: Sky
So anyone on this forum know how to do that then?Hi, you are putting the HTTP before the router IP are you, as I have the netgear one from sky and it is definately 192.168.0.1 to access it.
Anthony
Yea i have got that and i can log in to router's web interface but i cant use my internet connection upstairs it says says acquiring network addressHow to do what? If you're getting the username and password box, you've already got the router's web interface...
