Skybox Problem
18 Oct 2002
Brighton
After moving my skybox out of the way for some DIY, i put it back and now the thing just sits in standby and the light flicks off and on (red light) every 15 seconds or so.
I have forced a software download by holding the back up button and turning on, this seemed to work but the problem still exists.
Am i looking at a duff box? :(
Its a little amstrad box, this one: http://upload.wikimedia.org/wikipedia/en/b/b7/Sky-digibox.jpg
If i buy a Sky+ box, can i run it with one input temporarily. I can organise the second cable at a later date.
yes you can run a sky+ box with one input the second input is only for recording another channel while watching a different one.
Cool, so i got one with a freeview card and its all working tremendously.
Am i right in thinking that i phone up sky to register the box with my proper sky card?
Also, do i have to upgrade to a sky+ account to enable recording/pausing etc... ?
Thats an Amstrad DRX 500 unit.If you're handy with a soldering iron try replacing the caps indicated in the pix can be obtained from elex shops for a few quid.
