** SKYLAKE 6700K NOW IN STOCK & LIGHTNING AVAILABLE!! **
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
It has being hard to keep 6700k on the shelfs with demand being so high, but today we have over 1000 processors arrive:
Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - Retail @ £319.99 inc VAT
Intel's latest Skylake processor is manufacturered on 14nm process with an ultra-low upto 95W TDP. With improved efficiency and performance along with incredible onboard Iris DirectX 12 graphics platform.
Features:-
- Updated packaging materials
- Supported by new Intel Z170/H170 series chipset
Specification:-
- Lithography Process: 14 nm
- Cores: 4
- Threads: 8
- Frequency: 4.00 GHz (Turbo Mode 4.20GHz)
- Integrated Iris Graphics
- Cache: 8MB shared L3
- Memory Controller: Dual channel DDR3/DDR4 1600/1866/2133/2400/2666/3000/3200/3400/3600+ MHz
- Socket: LGA1151
- Memory compatibility: All DDR3L 1600MHz and DDR4 is compatible (Check your motherboards manual)
- 3yr Warranty
Was [£349.99] Inc. VAT
Only £319.99 inc VAT.
ORDER NOW
Also the 980Ti everyone has being waiting for and is certainly the Elite Tier of 980Ti and certainly the one my own personal money would go on, available first from OcUK:
MSI GeForce GTX 980Ti Lightning 6144MB GDDR5 PCI-Express Graphics Card (GTX 980Ti LIGHTNING) @ £659.99 inc VAT
The Lightning is amongst the best of the 980Ti's if not the very best, even our own 8 Pack had some input on the design of this legendary card with boost clocks out of the box close to 1500MHz possible and when overclocked around 1600MHz is possible (not guaranteed).
Ti. The most powerful two letters in the world of GPUs. When paired with our flagship gaming GPU–GeForce GTX 980–it gives you incredible new levels of performance and capabilities. GTX 980 Ti is accelerated by the groundbreaking NVIDIA Maxwell™ architecture to deliver an unbeatable 4K and virtual reality experience. With 2816 NVIDIA® CUDA® cores and 6 GB of memory, it has the horsepower to drive whatever comes next.
Features:
- Twin BIOS
- Enhanced Power Design: 12 GPU Phases, 3 Memory Phases & 10 layer PCB
- SuperPipe Technology: Three 8mm SuperPipes
- Triple Overvoltage
- Triple Temp Monitor
- V-Check Points
- Military Class components
- VR Ready
- DirectX 12 Ready
- 4k Ready
- 6144MB VRAM
Specification
- GeForce 980Ti
- GPU: GeForce 980Ti
- Core Base Clock: 1203MHz
- Core Boost Clock: 1304MHz
- Memory Clock: 7100MHz
- Memory Size: 6144MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2816
- DirectX 12: Yes
- DVI Port: 1x Dual-Link DVI, 3x DisplayPort & 1x HDMI
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Power: 2x 8-Pin & 1x 6-Pin
- 600W Gold PSU Required
- 250W-300W TDP
- Dimensions: L=330mm, W=140mm, H=53mm
- Warranty: 3yr
Only £659.99 inc VAT.
ORDER NOW
