- 28 Sep 2014
Hi,
I've previously had a few rigs powered by a 4790k/5930k and more recently a 5820k.
On these chips it was a case of upping the multiplier to whatever ratio (eg x46 for 4.6GHz) and manually applying cpu vcore in small increments then test stability using Aida64 or Realbench etc.
My new system is running a Skylake based 6700k but the overclocking settings are a little different.
I see many options under the voltages menu saying "Offset", there's actually 3 different settings that say offset.
Also, I noticed at idle, (using CPU-Z) my vcore fluctuates from as low as 1.056>1.256 and sometimes up to 1.32v!!!!
Is this normal?? Why such big fluctuations?
Is there any way I can keep the vcore static so it's constantly at 1.275v?
Also, with Skylake is it true that the CPU needs a lot more vcore than Haswell?
I've seen some reviews online which state that the vcore was pushed all the way upto 1.4v?
Any help in this area would be much appreciated.
PS - Mobo is MSI Z170 M7/2x8GB Ripjaws V 2666MHz.
Thanks in advance.
Thanks in advance.
