Skype crashes
18 Apr 2004
London
Hey all I am having trouble with Skype.
For over a month now when using Skype, if I open a message window to someone or they send a message to me it crashes the application, initially causing a spinning beach ball but then ending with a crash.
I have tried contacting Skype and Googling but there is no assistance to be found there.
I also tried spotlighting all files with the word Skype including system files and deleted them and the application its self and it still doesn't work. I also tried the latest beta and older versions performing the same delete each time.
I am really fed up with Skype not working and I can't seem to find any help anywhere else, I hope someone can suggest something else to try.
I don't know the exact error it reports back to Apple but its something to do with Kernel Protection Failure.
I get this all the time but don't know a fix for it. Would be interested to see if there is a solution. The current non-beta release has been out for ages now.
I assume you have uninstalled then re-installed Skype?
I am using Leopard (10.5.7) and have had no problems with it.
If you have Parallels/VM Fusion/VirtualBox, you can run the Windows version of Skype. Not a very elegant solution, but it depends how importantant Skype is for you.
