Skype Question ?
6 May 2008
Hi all, hope you can help just wondering does Skype need to be port forwarded? Or does UPNP need to be enabled in the router? Let me know how you have set yours up
Kind regards,
Depends on what you're doing. If you're making phone calls using VoIP you will probably need to use uPnP or port forwarding. Standard IM etc will be relayed via a central server of some kind and won't be bothered by NAT.
