skyrim - bluescreen crash?
22 Feb 2010
not a lot to say really, it can work anywhere between 8 mins and 8 hours, then it will randomly bluescreen. been running it medium settings (though it auto set to high at sat at 25fps :S) temps on everything are all well below threshold. is it really this unstable?
just to add, i can play a game like wow or league of legends for example, full settings + render a video or two in the background and it will be 100% fine, so im 99% sure its not my overclock. which is what makes me think its the game.
is there anything i could try as a temp fix for this?
No it is not that unstable. One thing to try that helped me and others is to reduce the sound settings. On the taskbar right click sound icon and select playback devices. Go to the speakers section and change the sound to 16 bit DVD quality. It may or may not help but this cured all my issues with Skyrim.
As I said this may not help you at all, but then again it might.
try making the games exe 4gb aware so its not limited to 2gb of ram it stoped all of my crashing , check the skyrim tweaks thread last page
