skyrim detecting gtx 670 as a gt 440?
12 May 2012
Peterborough
Any idea why it does this? The game plays fine, I was just curious why it's saying I have a gt 440. I'm on the latest beta drivers 304.48 so perhaps that's the cause but I can't see that being the reason. Anyone else had this happen?
sounds like a driver problem... never use beta drivers unless you have too
uninstall the nvidia drivers, use driver sweeper to get rid of every other nvidia driver/program from your system, and install the latest drivers (not beta)
this should work xD
Agree its likely to be a beta driver issue, although its a little strong to argue that the OP should never use a beta driver.....
That said if you do run beta's then you should expect to see exactly this sort of anomaly and others. The clue is in the name! ;)
